I'm not aware if there is such a function, but a quick solution to your problem is as follows:
1) Insert a text user column, e.g. "Text1"
2) Copy the entire "Task Name" column
3) Paste in "Text1"
4) Rename "Text1" as required
5) Hide/move the original "Task Name" column so not visible when printing
6) Print
You could also make a formula in "Text1" so it automatically copied and updated the value of "Task Name", meaning you didn't have to think about copying and pasting every time you modified your programme.
15 years 9 monthsThanks Again
Thanks Again
22 years 9 monthsKumar,a much easier way to
Kumar,
a much easier way to do:
1. in MS Project 2003/2007: go to Tools, Options, View, then unckeck the option "Indent name" at the bottom of the dialog box
2. in MS Project 2010: the same option is available in the Quick Access Toolbar, "More Commands"
Alexandre
15 years 9 monthsHi Johnson.. thnaks a
Hi Johnson..
thnaks a lot.It worked...
Rgds,
Kumar s
19 years 8 monthsHi Kumar I'm not aware if
Hi Kumar
3) Paste in "Text1"
6) Print
Bo
