Where does P6 Program files get stored in the system??
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hi i want to know how to get the backup programs i had a problem with my laptop due to motherboard failuer how can i get the programs
can any one help me in
where to put my Primavera P6 v7 license file
I do not know how to license the priamavera.
It's an emergeny for me and will be thankfull if any one can help
thanks
Haresh,
A simple check to have admin right to your machine is in explorer. Right click C: and select Properties then click Security tab. If you have all the right on the folder then you may have a admin right. Another way is click Start-> Control Panel-> Users Account. Check your username if set to administrator.
Hi Mr. Rodel,
This discussion is going out of P6 to administor rights on Machine (Vista)..Still i want to ask you ....do u know steps to check the administor rights in machine or change it , incase of any problem......
thanks
Haresh,
Do you have admin right on your machine? If you dont have admin right then that the reason why? If have admin right to your PC then try again using Window Authentication with different destination directory.
Dear Mr. Rodel,
I followed the exact steps , as you have explained in SQL Server Authentication , still i am unable to take the backup.
The message now is " Backup failed LG-PC/Primavera"
Additional info system.data.sqlclient.splerror:backup data permission denied in database pmdb$primavera.
Can u solve this problem....
regards,
Haresh,
You’re doing it correctly. If backup is failed the destination directory may not be existing or password may not correct when you logon to database.
Try this and it may work.
1) Run SQL express then when prompt users name and password change Authentication from Window Authentication to SQL Server Authentication. Enter username and password "privuser" for both.
2) Click Database node to expand and select pmdb$primavera.
3) Right click and select Task-> Backup...
4) Under destination backup to: Click remove button on the right.
4) Then Click Add and select a new destination folder (not under MSSQL) and enter a new name.
I understand now where does this file is stored. I tried to save back up from SQL express by using following steps.......but unable to do it.....
I select the Database Pane, Summary Tab, pmdb$primavera then right click --> Tasks --> Back Up
Database: pmdb$primavera
Backup Type: Full
Backup Component:
-Database
Backup set
Name: pmdb$primavera-Full Database Backup
Destination
Back up to: -Disk
C:\Program Files\MSSQL\Primavera\MSSQL.1\MSSQL\Backup\pmdb$primavera.bak
and then I select OK. However, I received an error message: Below is the ERROR MESSAGE:
Backup failed for Server HP-PC\PRIMAVERA. (Microsoft.SqlServer.Express.Smo)
Additional Information:*
System.Data.SqlClient.SqlError: The server principal "hp-PC\Haresh" is not able to access the database "pmdb$primavera" under the current security context. (Microsoft.SqlServer.Express.Smo)
Any solution .......
Haresh and Hannes,
P6 has files and it is stored in SQL-Database. The database name is PMDB$Primavera_DAT.MDF. It is run under master Database (master.mdf). These files are called SQL Databases. As I mention to my previous post it can be back-up using SQL Server Management Studio express.
To check if this installed click Start->Program->MSQL Server 2005 or 2007(defends on p6 version)->SQL Server Management Studio express.
The database normally stored on this location for standalone
C:\Program Files\MSSQL\Primavera\MSSQL.1\MSSQL\Data
Haresh
P6 does not store your projects into a file. As MS-SQL is part of your operating system, the SQL-database is no file.
As described, you can make a bak-file of it, which can be transported to an other system. This Bak-file includes everything of yr database: projects, calendars, WBS, activity codes, ...
To create this backup-file and also for restoring use SQL-Server-management-studio-express. Also search in this forum for instructions. Keywords: SQL, pubuser
Dear Rodel,
I followed the procedure instructed by you. But unable to locate the date folder in any of my primavera files.
I also want to know under which extension file , does this files get stored?? Pls guide me again
Haresh,
Primavera (P6) is consisting of 2 parts. One is the client which is the Primavera Program and Database running either Oracle or SQL server which ever is you used when you install Primavera. Primavera client program is under Program files-> Primavera folder. There are 2 Primavera main programs (Project Management (P6) & Methodology Management). The other part is the Database under Program files-> MSSQL-> Primavera and soon… There are many folders inside but the data itself is under data folder. To back-up this data there is software included in Primavera CD called SQL Server Management Studio Express. It manages Primavera Database and can use for backup all data in the Database.
If you want to re-install Primavera, it doesn’t overwrite the database and only reinstalling the client. Primavera recognizes the database and will not overwrite including the SQL server. But I’m not sure if re-installation will fixed the problem because users name and password are stored in Database and not on Primavera client. Try to backup first and un-install everything including SQL Database if re-installing client will not have a success.
