Activity step in P5 (import/export issue)
Y
Yusuke Kamui 👤 Member for 18 years
Hi, importing it to excel does not give me an option in P5 to select the Activity Step Name and Activity Step Description columns. Weird isn’t it? Why P5 don’t allow those columns to be exported to Excel so that I can edit it and import it back to P5??
Thanks by the way....
Y
Hi, imporitng it to excel does not give me an option in P5 to select the Activity Step Name and Activity Step Description columns. Weird isn’t it? Why P5 don’t allow those columns to be exported to Excel so that I can edit it and import it back to P5??
Alex Wong 👤 Member for 23 years 4 months
You can just import it using the import function provided by the application.
In addition, there are tools in the market will help with very specific need to importing data into P5.
HTH
Alex
Y
Hi Alex, thanks for the reply, but again the main objective is to import to P5 those data have in Excel to be used as an activity step template. Once I’ve done what you said, sure I can open it to Excel but after I edit it excel how to return it back to P5 to be used as an activity step template?
Another way to do that is -
Report - Add - New Report - Activity Steps - Activity Steps - Columns (Step Names, Step Descprition), Filter , Group and Sort .... Save report.
Once you saved the report you can open the report in CSV file format and it open in excel
HTH
Alex
Y
Thanks for the reply but a problem on #5 - "On Columns Tab Select Activities, Activity Steps data to export and activity name if necessary, otherwise accept the default."
There is no Activity Step Name and Activity Step Description. These are the 2 important columns I need to export.
The only column I can add under Activity steps are: Activity Step Count, Steps Completed, Steps in Progress and Steps Not Started.
Please help.
Arnold Puy 👤 Member for 19 years 1 month
Yusuke,
Below are the Steps of export/ import method for Activity Steps.
Exporting Activity Steps to Excel:
1) Select File-> Export-> Spreadsheet - (XLS) and click Next
2) On Export Type tick Activities and click Next
3) On Project to Export -> Select the Export click box of the project you want to export and click Next
4) On Select Template click Add and rename your template for future use and tick Modify
5) On Columns Tab Select Activities, Activity Steps data to export and activity name if necessary, otherwise accept the default.
6) Select Filter tab and click Add
7) Rename your Filter
8) Select Data that you wanted to export and click OK then click Next.
9) On Select XLS File click and change the destination directory and filename so you can find it easily when modifying the data then click Next and Finish.
10) Open your exported excel file and you should have two tabs on worksheet correspond to “TASK” and “USERDATA”
11) From your excel sheet modify / edit changes
12) Save as your excel file to a new name so you can import it back to P5 Project
13) From P5, Select File-> Import-> Spreadsheet - (XLS) and click Next
14) Select File to Import and select the new excel file that you just modified and click Next
15) Tick Activities and click Next
16) Click Import To column and select the active project that required changes and click Next then Finish.
Arnold
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
