P3.1 RESOURCE LOADING
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hello Rio,
Let me guess on this one... Probably,.. you have to check the settings of your resource loading report.
Highlight your particular resource loading report on the menu bar,..click MODIFY.. go to FORMAT.. and check the DIVIDE BY box below.
In order to yield the same quatity with the bugdet when this is set to run, the divide box should be set to "1".
Otherwise, for example,.. if that box was set to "2", then this will give you half of the BQ.
Hope this helps...regards.
Gerry
