duration calculation in p3& p5
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
hi
John
Thanks for your help it solved my problem.
Thanks PP
Mangesh
Mangesh
This is only a guess but check it out.
I assume your planning unit in P3 is Days. In P5 the planning unit is always hours, but appears as days. You will need to check the hours/day in Admin|Admin Preferences|Time Periods. This deterimnes the calculation for hours per day etc.
You may need to change the duration, then change it back, for the duration to be re-calculated.
Hope this helps.
