P5 Project group export issues to P3
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Thanks Dieter,
Keep Planning.
Kevin.
Hi Kevin
You can copy a project group as a project into another project group. It will be possible to export the three P5-Projects to P3. You’ll have 3 project groups. Then copy those P3-projects into a fourth (new) Project. To this for the complete life of your projects will be a horror.
It is a break of structures. In any case you’ll loose informations.
Maybe another solution will help: I suppose, planners in construction area want to keep their old P3 and reporting has to be done in P5. In such cases -if it’s not possible to convince old planners that a common solution is better, I let them schedule in P3, import with "update" into P5 and do the reporting. Import then only will be one-way and with reliable results.
