Duration with decimal point...
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hi Rick,
The calculation in P3 works in whole units - your only option for parts of a day is hours, but you can run a secondary schedule, for example a steel erection schedule, and import or key in a summary level into your main schedule. Even if your client demands it as backup it will only detail one part of your work.
Hi Rick
No you cant! I agree to Raviraj, without decimals should be ok for longer projects. In P3e it would be poosible but there too I didnt use it - for longer projects.
Hi Rav and Anoon,
Thanks for your immediate response, but is there a possibility that i could set up my duration with a decimal point? like 2.3 days, 2.4 days, etc, etc. because when i enter the duration with decimal point the primavera will round it off to a whole number, and when you organized it to see the schedule duration it is less of what i have planned.is there a possibility for p3 to accept whatever duration i encoded.
Thanks Again.
Hi Rick,
If the project is long, why u want to put duration in hours. Do u want to be so transparent with ur client that u will activity worth in hours only.
Even, it is neither required by Client/Consultant nor by project team.
Hours are used in mostly maintenance projects, where shutdown means loosing money.
Its of no point in putting duartion in hours for a long project
Raviraj
i suggest that you should never do that, if its day or hour so be it!
