P3 3.1 Layout
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Thanks, Now i tried ur options and coming ok. So it was a problem with my default layout.
Nazarulislam,
You may not have a default layout set on P3 but you can make one.
Follow this step to set a default layout for new projects.
1) Open a project that having a layout that you want set as default.
2) Select View-> Layout-> Make Default
3) If prompted “Replace the default” Click Ok.
That should set your default layout for new projects.
Rodel
hi,
Thanks for ur reply Mr.Rodel, I also used to open a project with working layout and then i used to transfer. But why this is happening? Whenever i start a new file, my layout is not of classic schedule, but some other layout from my older file.Why it is so?
Nazarulislam,
Check your bar settings. You might not tick the show box or it maybe overlaping on other bars rows. If you are not sure how to do it, open a project that the layout is working for you then transfer it to your new project. Otherwise let me know if you need assistance in setting a bar.
Rodel
