Adding and Removing Projects from the Master
T
Terry White 👤 Member for 22 years 4 months
Ashraf Jahangeer 👤 Member for 19 years 1 month
Hi Terry,
I also encountered the same trivia while working on my project. Although the project is closed still for historical records it has to be retained in the system.
What I do is make a copy the project and then delete the original from the master. As to add the project again to master I again copy the project in the master project group.
Hope this clarifies your querry.
Ashraf
Alexandre Faulx-Briole 👤 Member for 23 years 4 months
Terry,
a project is "closed" when every activity is 100% complete, isn’it ?
you could possibly add a project code "Status" that says something like "Not started, Running, Closed"
Alexandre
T
This may sound like a silly question, but how do you ’Close’ a project please ?
Terry,
I would use a filter to display ALL activities except those belonging to the closed projects; I would certainly not remove the closed projects from the master project, in case I need to work on the whole lot of data some day later.
Alexandre
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
