Read only project
This is a simple fix. Run Windows Explorer (or click on My Computer.) Find the C: directory holding your P3 schedules and click on it. Right click to bring-up the menu and select, "Properties". Look to the bottom of that screen where it has a checkbox saying, "Read Only." Uncheck it and close everything.
P3 should run fine now. Good luck!
J
Jose Frade 👤 Member for 21 years
Hello,
I had a similar problem when simply copying from the CD tothe Hard Disc.
Then, I restore the project from within the P3 (Cd to HD).
And the problem was not happening anymore.
I hope this would help to solve your problem.
BR
JMFrade
P
Praves Suppa 👤 Member for 20 years
Hello dude,
I experienced inadvertenly about Read-Only File once my backup PRX.File was set up the attribution to be Read Only in Property (Checking by Right Click at the PRX file you need to restore and open it)
Perhaps my case would be remind you for checking. Hope moreless can help as at least I was the one who used to.
Have a nice day.
Praves
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
