Scrooling in P3 V3.1
J
Jose Frade 👤 Member for 21 years
I had this problem since ever P3.1 was issued.
I used already both methods to correct it.
At present I’m using still Windows 2000 in one of my laptops and a mouse from Logitech for which the manufacturer does not supply a driver. in this case the solution was to find an adapter USB->PS2 and then the wheel works.
In the past I was using a mouse for which the manufacturer was supplying a driver that came with it. I installed the driver under Windows XP and also worked OK..
I hope ite helps.
JMFrade
S
Shareef Abdul Azeez 👤 Member for 20 years 8 months
Are you sure Jose.?
Coz this is the first time I am hearing this!
Even i have had the same poblem for long!!!
What is it that i have to do exactly
Can u get down a little more precise
J
Yes, it is possible.
I guess you are experience some problems with the scroll wheel.
There are several ways to solve the problem:
1. Load the manufacturer mouse driver instead of using Windows drivers.
or
2. If your computer has the PS2 mouse port use it instead of USB.
JMFrade
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
