Simple Grouping Query
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Thanks George / Zhang
Worked a treat !
JP
George Stewart is right. you can also set up activity code for sorting (eg ORD1,ORD2)
Maybe I am not quite understanding your query, but here goes. When you were setting up your codes/values/descriptions there is a column on the left showing order. You use this to show the sequence you require by numbering from 1,2,etc.
This will then allow you to achive your requirements.
Hope this helps,
George
