export from P3 into xls including grouping structu
Z
Zhang Haixiang 👤 Member for 21 years 2 months
What you need to do is just sort your activities then add a group title.
if you have too many to add, try excel’s outline worksheet function.( I’m using excel 2002,it has the ability to group rows/columns)
Razi Khan 👤 Member for 21 years 11 months
Then why don’t you give report in pdf format instead of Excel.
E
Eckart Schenck 👤 Member for 21 years
I’m familiar with sorting by act codes in xls.
The problem comes when you communicate with somebody who doesn’t know well the act code structure and doesn’t have P3 either. In such case it would be good to have an excel export with the grouping...
Heinz
Export with "Activity Code" Columns also and then sort and group in Excel as per requirement.
Cheers.
J
Jaco Stadler 👤 Member for 21 years 9 months
Henk Export the Activity Codes as Well then when you are in XLS you just sort or Subtotal By Structure
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
