Logo on Layouts
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hunais M J
I have do some tests before. Same logo in different format, so different file size. Then same printer driver, some work, some not (even in preview). In most situation, due to the size of logo file is too big. I check the print queue size also, not only just print out or not). Some successful print out but the logo from colour to B/W only.
Then select those successful logo file with different printer driver to same printer, do the test again. Some printing failure. Those printer drivers are standard, postscript and PCL.
Hi All,,
I have met this problem in the past..I found this problem comes from big file size..once I convert the file to Jpg formate or gif..with smaller size.(you can adjust the size through Adobe photoshop or Illustrator)..it works.
If the Printer Memory is supporting the big file size..it will print..it depends upon the memory of the printer mainly.
Ali Hamouda
hi Mark,
try to make new layout without (Layout - Transfer), then try t oinsert the logo, i think it will work. if not, convert the logo from BMP to PMT this is a guaranteed method
regards,
Ahmed
Yes i did mean C:P3win Just a typing error. Any ideas now then?
You mean that the path is "C:\P3WIN" do you not? The difference between your answer and this one may be the answer to your problem.
I have tried different logos with different size files and still no luck. The path is C:p3win so very short.
I have just seen a copy within the company that does not even allow you to attach a BMP file. It comes up with File format unknown. Any Ideas
My experience: -
- If the logo file size is big, fail to print
- The printer driver support the logo format or not, same printer may have standard driver, postscript drive, PCL driver. All have different result
- Location of logo file. Long path is not recommended.
We are using P3 Ver 3.1 with Windows XP. We have the latest service pack installed. We have tried different logos and different printers.
LOGO is printed in P3 without any problem if it is properly pasted from image file and also your printer set up is correlate with the Printer
It does print logos .May someproblem with printing harware.Like less memory or so.
