P3 / MSProject 2002
J
Jorge Taguinod 👤 Member for 22 years 11 months
Hi Anita,
A few differences between Primavera & MS Project:
PROJECT LEVEL
- Enhanced Security
- Concurrent Multi-user
- Specify Both Project Start & Finish Dates
- Correct Total Float
ACTIVITY LEVEL
- 9 Activity Types (vs. 2)
- Multiple Relationships between activities
- Accurate Late Dates for all activities
- Advanced Constraints and Multiple Constraints per Activity
- Suspend & Resume
- Automatic & Manual Scheduling
- Advanced PERT Features
RESOURCE & COST
- Central Database
- Advanced Resource & Cost Profiles (S-Curves, Resource Load Analysis)
- Dynamic What-If
- Advanced Leveling (More Control & Better Results)
REPORTS
- Tabular: 101 Predefined
- Graphical: 47 Predefined
- Advanced S-Curve
- Earned Value Analysis
- Web Publishing Wizard
- Cross-Project Reports
In summary, MS Project is easy to learn because it has much less features. But when you try to use it on an actual construction project, you will find it severely wanting and incapable of doing what you need.
One the other hand, Primavera & SureTrak, are the established project management software for the construction industry worldwide simply because these software products have been proven to work.
Jorge
J
There might be some comparisons that Primavera would be willing to send you. You can write them and ask. Go to primavera.com and post your querry.
If you have current P3 maintenance, then you could probably search for the info yourself at their knowledgebase. I have seen some confidential comparisons made but Im not at liberty to reveal.
If you have a P3 dealer near you, theyre sure to have access to this information.
Jorge
Crown Systems (Philippines)
E
Ed van der Tak 👤 Member for 24 years 3 months
Anita,
All depends on the structure and information needed within the different levels of your company. Both software packages (P3 and MSP 2002) can be delivered in a "normal" version or the Enterprise version. A combination of both (P3e with "normal" MSP 2002) might be an option but a formal procedure for the definition of the activities and codes needs to be in place. Based on your few lines I cant give you more info, but Im well prepared to react to a more detailed e-mail.
ARAM Planning Consultants is already working for several UK based construction and claim companies.
Let me know if your interrested and need more info.
Bye,
Ed van der Tak
The Netherlands
e.vandertak @aramplan.com
T
Tara Muddappa 👤 Member for 23 years 5 months
Hi Anitha,
Though i have not used MS2002 extensively,but a review of the software suggest it is definetly inferior to P3.
I find P3 an excellent tool for network analysis and this is what is required to control and monitor a project.
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hunais M J
