Organize coding by Activity ID
8 replies [Last post]
Jacob Emmanuel
User offline. Last seen 10 years 37 weeks ago. Offline
hi fellow planeteers
i cannot find activity code by activity id just like in p3?
was it removed in P6 now?
Thank You.
Jacob Emmanuel
thanx R and Arnold
so there is no automatic grouping right?
in P3, let’s say we have 10 activities
A010 A020 A030 B010 B020 B030 C010 C020 C030 C040
in activity code under activity id tab
i will create GROUP under codes, A0 as GROUP 1, B0 as GROUP 2, C0 as GROUP 3 under values
then organize by GROUP
automatically it will organize right?
so for P6, the assignment is like Activity Code only right?
R. Catalan
J. Eman U,
Group by Activity Code, then Sort by Activity ID.
HTH,
R. Catalan
R. Catalan
J. Eman U,
1. Select all activities with the same Activity Code
2. Right click on these activities > click Assign > click Activity Codes > select Activity Code from "Assign Activity Code" window > then click Assign button.
3. Repeat 1 & 2 for other activities.
Then follow Arnold’s post for grouping and sorting.
R. Catalan
Arnold Puy
User offline. Last seen 9 years 34 weeks ago. Offline
Hi Eman,
First of all, you need to assign the activity codes to all activities by selecting those activities to their coresponding activity codes using the CTRL or SHIFT and select the Activity Codes Command Bar Button located at the right corner of your screen.
Or you can show the Activity Codes ID on your column and use the "Fill Down" in Edit Menu.
If done, go to Group & Sort.
Hope this helps.
Arnold
Jacob Emmanuel
hi arnold
then i will need to assign them one by one?
no automatic grouping like in p3?
Arnold Puy
Go to "Group & Sort", and Group By and select the "Assign Activity Code"
Jacob Emmanuel
thanx but i am asking activity code by id, like in p3 no need to assign it will automatically be organized using the first few letters in id.
where is it in p6?
Arnold Puy
Hi Eman,
Go to Enterprise Menu --> Activity Codes.
Cheers.
