Project integrity report - Project/WBS mismatch
6 replies [Last post]
Maya C
User offline. Last seen 15 years 42 weeks ago. Offline
Application: P5
When our IT person ran a ’project integrity report’ this morning the following error was reported. We are not exaclty sure what this means or how to correct it. Any thoughts?
The error was:
18. Check Project for: Project mis-match between Projects and WBS
>>>Errors:
Project: - Not Fixed: Please examine and correct the data manually.
>>>OK
Ellyn Gilbride
User offline. Last seen 13 years 18 weeks ago. Offline
Got it. Thanks, Dieter.
Dieter Wambach
User offline. Last seen 7 years 23 weeks ago. Offline
Ellyn
Sorry for bad expression.
Try to add a new document and assign it to an activity and to a WBS --> F10 (Commit changes) --> F5 --> delete --> run integrity check.
Target of this action is to write into the table with the documents then to write again - the deletion-flag. My hope is that Oracle or MS-SQL recognizes a mismatch and corrects. Same idea as for the WBS.
(I’ve some impression of a bug in P7 or in the transfer program from P6 to P7)
Good luck!
Ellyn Gilbride
Dieter,
Thanks for your reply. The Primavera release I’m using is update 7 for P6, so it’s P6.7. :)
This is a brand new project so nobody else has even looked at it. I am the only scheduler in the office right now, so no one could have had it open.
I will try your solution of adding/F9/deleting a WBS. Seems a new quirk turns up in P6 every other week, but I still love the application.
I don’t know what you mean by trying analogue with a document. ???
Ellyn
Dieter Wambach
Ellyn
Sorry, I have no experience with P7. Was there everything ok with the transfer of the database to the new version - log-file checked? Check Primavera POINT for a known error.
Recently I had that issue (WBS mismatch) as well. Since didn’t like to take the risk of using SQL in a productive system, I tried inside P6:
- Checked if someone else was working with that project -->
- Opened exclusively -->
- Added WBS --> F9 --> deleted this WBS --> ran integrity check
After three - why, I have no idea - times this error disappeared. I would try anologue with a document.
Good luck!
Ellyn Gilbride
Dieter,
We just updated to Primavera 6.7 and I ran the Integrity Check for the first time on a new project. I got the same error: Check Project for: Project mis-match between Projects and WBS
I have no idea what that means or how to fix it - or even if I need to do something about it. Do I?
I also got this error: Check Document Assignment for: Project mis-match between Document Assignments and Work Products and Documents
Document Assignment: - Not Fixed: Remove mis-match Document Assignments
There are no work products or documents or document assignments.
Can you help?
Ellyn
Dieter Wambach
Maya
This error is a little dangerous. There seems to be a mismatch within the projwbs table. If you don’t report progress via time sheets, create a new project and move everything of the damaged into the new project.
As far as I remember there was an issue in 5.0 but solved by a patch. Check if you installed all service packs.
Good luck
