P5 Installation help
11 replies [Last post]
ulysses garcia
User offline. Last seen 13 years 35 weeks ago. Offline
Groups: GPC Qatar
Hi all,
I you need help to install P5, send me you e mail address , i will give you the details
Dieter Wambach
User offline. Last seen 7 years 23 weeks ago. Offline
These are Windows rights. Primavera needs to write into the registry.
It has to be done by your PC-Admin
DOROTEO CALIMLIM
User offline. Last seen 16 years 29 weeks ago. Offline
How to establish the local administrator?
Dieter Wambach
Hi Doroteo
I assume, you have no local administrator rights on your PC. You’ll need those to establish the connection to a local database.
DOROTEO CALIMLIM
Dear All,
Im trying to install the P5 on standalone PC, but before that Im setting up a database using database wizard.
The error messages says "SQL Server Error:[DBNETLIB][ConnectionOpen(Connect).]SQL Server does not exist or access is denied
Ronald Winter
User offline. Last seen 3 years 29 weeks ago. Offline
Even Primavera admits that P5 will not run under the Vista Operating System. If you have Vista, you will need to buy a copy of XP and switch over or forget trying to run P5. Good luck!
Dieter Wambach
hola Javier,
This error message just indicates that P3e isn’t able to cooperate with your SQL-Server, either access rights (wrong in this case) or not at all (assumes it doesn’t exist). Under other Windows-Operating Systems it would be possible to run your server in 2000-mode and it would work, but not with Vista.
saludos y hasta luego
Javier Reveco Docal
User offline. Last seen 17 years 11 weeks ago. Offline
Ulysses
don´t work, present a problem in database configuratíon, "bad public user name or password. SQL Server Erro: [DBNETLIB][ConnectionOpen (Connect()).No existe el servidor SQL Server o se ha denegado el acceso al mismo.;"
I have instaled MS SQL Server Management Studio Express 9.00.3042.00
MDAC 6.0.6000.1638
do you use other version or other program?
ulysses garcia
Groups: GPC Qatar
Of course it works, not like p3
Javier Reveco Docal
Works in Windows Vista?
ulysses garcia
Groups: GPC Qatar
Nestor and to all,
This procceedure will begin from Database Configuration;
Look at the MSQL server at the bottom of your desktop, make sure ; it is running then in the configuration setting
just click next, then select PMDB then click next.. do not attemp to put password in the middle of the installation , just leave it blank, then clict next,
At the near end of your task , it will ask you only 1 password, then enter admin..
then run... i hope you will be succesful.
Dont hesistate to ask me again if you have difficulty for it.. maybe its not clear for you
regards, uly
nestor docot
User offline. Last seen 6 years 6 days ago. Offline
Good Evening
Ulysses,
Can you give me the details in installing P5. Here’s my
email. nadocot@dmcinet.com or nadocot@gmail.com
Many Thanks
Nestor
