P3e basics
mh shaw
User offline. Last seen 16 years 3 days ago. Offline
when i was adding activity i click constraint "yes" * appeared on the activity. How can i remove this * sign from activity
Andrew Dick
User offline. Last seen 8 years 37 weeks ago. Offline
If they are still there and you can’t work out why.
As I’ve just found out, if you have no requirement for Logic links to external projects, add the columns ’External Early Start’ & ’External Late Finish’, then remove any data in there.
This will then clear the remainder of the "*".
Andy
mh shaw
Thanks for your help
User offline. Last seen 17 weeks 2 days ago. Offline
mh shaw,
On the activity detail select the status tab and remove any constrains and date shown on the constrains box
Hope this help.
Rodel
