How to change the Activity ID of a group of activities?
7 replies [Last post]
Pranab Kumar Deb
Dear All ,
How to change the activity ID of a group of activities in faster manner and not by manually for all the activities.
I tried with import/export but the problem is that the activities where i change the activity ids comes in as new acivities.
Please advice.
regards
deb
Pranab Kumar Deb
thanks daniel , ferdinand and dattareya
it was a great help
regards
deb
Daniel Limson
User offline. Last seen 5 years 31 weeks ago. Offline
There is another way of doing it by copy and paste. Select auto increment and delete the ones you want to change. The only problem here is you will loose the relationship outside of the group you copied and pasted.
Daniel
Ferdinand U.
User offline. Last seen 7 years 26 weeks ago. Offline
example change A100000000 to B200000000
global change
if ACT CN A1
then ACT EQ B2 & right(ACT,8)
run
Pranab Kumar Deb
Hello Ferdinand and Dattatreya ,
can you please list in more details the procedure.
regards
deb
DATTATREYA PADHARTHI
User offline. Last seen 6 years 12 weeks ago. Offline
Pranab,
Use the Global Change; if you want to change a charecter/s in the middle, extract all charecters before that lot and also extract all charecters after that lot and save as a temporary variable. then use the concatenate function.
Dattatreya
Pranab Kumar Deb
Hello Ferdinand,
Thanks for your reply can please elaborate how to use this function.
regards
deb
Ferdinand U.
try global change using the &T1 function &..
