P6 Installation help
ananda vijayan
User offline. Last seen 13 years 18 weeks ago. Offline
Dear friends,
Currently i am using P5 with windows XP(SQL server 2000). Now i want to upgrade P6. But I have problem with P6 installation.
1. Runing SQL server 2005 setup, SQL server database services menu showing the following error. "SQL server setup cannot perform the upgrade because the component is not installed on the computer. To proceed, verify that the component to be upgraded is currently installed, and that the component to be upgraded is specified in the ADDLOCAL property. For more information, see running setup from the command prompt in SQL Server Books online."
2. After completion of the P6 setup, the following error appear, " Bad Public user name & password. Database server error, SQL network/Interfaces. Error locating server / Instance specified. (XFFFFFFF)"
Kindly help in the above matter.
Thanks in advance,
best regards,
VJ
ananda vijayan
Dear djouallah,
Thank you for your advice.
But not working that username & password.
mimoune djouallah
User offline. Last seen 5 years 10 weeks ago. Offline
hi
for question n°2
try this
system admin name : sa
system admin password : prima123vera
when you configure your connexion to sql server
HTH
ps: i don’t have p6 installed yet,
