Detaching the baseline
7 replies [Last post]
adab azeez
User offline. Last seen 2 years 40 weeks ago. Offline
Greetings to everyone. I have to detach the baseline to modify some duration and some calenders. After modification I am expected to re assign the same base line. Any Suggestion , what precaution should I take during this...? Thanks in Advance.
User offline. Last seen 26 weeks 3 days ago. Offline
I told you how to detach a schedule nothing fake about that
Anoon Iimos
User offline. Last seen 2 years 37 weeks ago. Offline
Adab, Tip: Don't always believe in everything you read, especially if the source is unreliable. Nowadays "fake news" are rampant. Beware!
yes NEVER use progress over ride
Anoon Iimos
Now this becomes interesting. Adab, comparing baselines and current schedules need to be consistent (consistency is the key). Though of course there will always be some details to vary, as plans don't always turn out exactly the way you planned them. Just be careful with the settings (I mean "Retained Logic" vs. "Progress Override", I guess you already knew how and where to use them?).
reverse the way that you attached it
select project
then assign baseline
then under Project Baseline select <Current Project> as the baseline
als under User Baseline
Primary select <Current Project> as the baseline
select OK
next under project select Maintain Baselines
highlight the scheduel that is listed there and on the rigth select Restore
Kannan CP
User offline. Last seen 11 weeks 23 hours ago. Offline
Hi Abad,
If the changes are only in baseline and not in current Program, probably you would be comparing Programs with different logic, duration, productivity resources etc.
BR
Kannan
Anoon Iimos
Is there a problem with removing or detaching your baseline and do the editing as a stand-alone schedule, and then assign it back to your current or working schedule whenever you want? Well, I guess you need to make sure first that your baseline is the exact copy of your current schedule whenever you attach or detach it. Exact copy means: exact number of activities and descriptions. Of course other details may vary depending on how your plan is progressing actually.
